HTTPAPI and http_parse_xml_stmf error
rishabkshk
Post by rishabkshk »
First of all thanks for making the life easier for us. It is truly beyond words, the work you have put in for the IBM i world.
I am having some programs erroring out for some reason when using http_parse_xml_stmf to parse xml documents on the IFS(stmf with ccsid 1208). The error is happening in the callback procedure. Below is the error occurring when moving `value` to the target field.
Message . . . . :   Length of varying length variable is out of range.
Cause . . . . . :   The length of a varying length character or DBCS variable
  is less than 0 or greater than its declared maximum length in RPG procedure
  RESPONSE in program xxxxx.
Response procedure:
P Response        B
d Response        PI
d   userdata                      *   value
d   depth                       10I 0 value
d   name                      1024A   varying const
d   path                     24576A   varying const
d   value                    32767A   varying const
d   attrs                         *   dim(32767)
d                                     const options(*varsize)
if (path = '/soap-env:Envelope/soap-env:Body/nm:WELSING/INPUT/POSDRER')   ;
     Select;
     When (name = 'PO');
        PurchaseOrder = %trim(value);
    ENDSL;
Below is how it is being called:
If (http_parse_xml_stmf( %trim(xmldocpath)
                       : HTTP_XML_CALC
                       : *null
                       : %paddr(Response)
                       : *null ) < 0 );
EndIf;
Also the dump for the `value` variable :
VALUE                 CHAR(32767)          VARYING(2)
                                           '      ÿ· o4hpØ                                                Ø       H¸   ;º   '
                        81                 '                                     è                      ENDELEMENT          '
                        161                '              Ø       H¸   ;º           *N                                      '
                        241                '        '
                        321                '        '
                        401                '        '
                        481                '        '
                        561                '        '
                        641                '        '
                        721                '        '
                        801                '        '
                        881                '        '
                        961                '        '
I have also created another pgm to try and debug but it works well there. The issue is intermittent and does not occur on every file process. If there was any issue with the xml, then the program wouldn't work the second time for the same file. Only the `value` variable has junk data.
I also tried changing ccsid on the http_parse_xml_stmf and HTTP_XML_CALC has reduced the errors substantially but not all.
What could be the probable cause? memory corruption? activation groups? I am out of ideas at this moment.
Re: HTTPAPI and http_parse_xml_stmf error
What is the hex value of the first 4 bytes of the 'value' parameter?
How can this problem be reproduced?
rishabkshk
Below is the dump output
VALUE IN HEX         '8000000000000000D5F200B07C9EB740000000090000000000000000000000000000000000000000'X
  41                 '0000000000000000000000000000000000000000000000008000000000000000EF5FBFD6134F1EB0'X
  81                 '00000000000000000000000000000000000000000000000000000000000000000000000A00000054'X
  121                '00000000000000000000000000000000000000000000C5D5C4C5D3C5D4C5D5E30000000000000000'X
  161                '000000000000000000000000000000008000000000000000EF5FBFD6134F1EB04040404040404040'X
  201                '40405CD5404040404040404000000000000000000000000000000000000000000000000000000000'X
  241                '00000000000000000000000000000000000000000000000000000000000000000000000000000000'X
  281                '00000000000000000000000000000000000000000000000000000000000000000000000000000000'X
There is no way to consistently reproduce it. It keeps working until it does not.
The first 2 bytes of the value are x'8000', which means the length is 32768, since the parameter is defined as 32767, you are getting the error.
You talk like the error is sporadic, but... doesn't it happen consistently with certain XML documents? If you do the same document again, you don't get the error? That surprises me very much.
On the other hand, if a particular document does it consistently, I could probably solve the problem. But if its sporadic, I don't know what I can do.
rishabkshk
The error does happens out of nowhere and when I try to process the same file again, it works fine. Appears to be some kind of memory corruption but I am really not able to reproduce it successfully. They say, "it's a bird on a wire" :lol:
As I workaround, I am thinking of rewriting the program with sql functions or add error handling to the existing code.
