Error with HTTP Header in V1.53
kwengert
Post by kwengert »
Good Morning,
First of all, thank you Scott for creating this great API. I've been using it for about 10 years at several of my clients.
One of my clients is updating their WMS, and I need to update my interface to make that work. As I was doing this, I decided it was time to update to your latest release of HTTPAPI. In doing that, I have found a problem where the SOAPaction on the http_url_post_stmf is being truncated to 64 characters. In reseaching this in the HTTPAPI_H member, I see that the original length of that variable was 64 characters. I'm not sure if did something wrong with the installation or if there is actually a problem in the new version.
Here is the code:
          //  Post Assignments
          rc = http_url_post_stmf(%Trim(URL)
                            : wFile
                            : wResponse
                            : HTTP_TIMEOUT
                            : HTTP_USERAGENT
                            : 'text/xml; charset=utf-8'
                            : 'http://SelectorPro.SAESystems.com/Import/' +
                               'IImportService/ImportAssignments');
Here is the debug log from V1.53
HTTPAPI Ver 1.53 released 2025-10-15
OS/400 Ver V7R4M0
http_url_post_stmf(): entered
getting post file size...
opening file to be sent...
opening file to be received
DNS resolver retry  : 2
DNS resolver options: x'000001B6'
DNS default domain: MAINES.NET
DNS server found: 10.1.2.35
POST /selectorpro/importservice/soap11 HTTP/1.1
Host: 10.1.2.111:8000
User-Agent: http-api/1.43
Content-Type: text/xml; charset=utf-8
SOAPAction: http://SelectorPro.SAESystems.com/Import/IImportService/ImportAs
Content-Length: 9873
sendraw(): entered
<Soap document inserted here>
HTTP/1.1 500 Internal Server Error
Content-Length: 762
Server: Microsoft-HTTPAPI/2.0
Date: Fri, 07 Nov 2025 20:27:42 GMT
SetError() #13: HTTP/1.1 500 Internal Server Error
recvresp(): end with 500
recvdoc parms: identity 762
recvdoc(): Receiving 762 bytes.
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><s:Fault><faultcode xmlns:a="http://schemas.microsoft.com/ws/2005/05/addressing/none">a:ActionNotSupported</faultcode><faultstring xml:lang="en-US">The message with Action 'http://SelectorPro.SAESystems.com/Import/IImportService/ImportAs' cannot be processed at the receiver, due to a ContractFilter mismatch at the EndpointDispatcher. This may be because of either a contract mismatch (mismatched Actions between sender and receiver) or a binding/security mismatch between the sender and the receiver.  Check that sender and receiver have the same contract and the same binding (including security requirements, e.g. Message, Transport, None).</faultstring></s:Fault></s:Body></s:Envelope>
Here is debug log from the version running in production for the last 9 years:
HTTPAPI Ver 1.31 released 2016-02-03
OS/400 Ver V7R4M0
SOAPAction: http://SelectorPro.SAESystems.com/Import/IImportService/ImportAssignments
Content-Length: 51676
sendraw(): entered
Content-Length: 350
Date: Thu, 31 Jul 2025 15:48:29 GMT
recvresp(): end with 200
recvdoc parms: identity 350
recvdoc(): Receiving 350 bytes.
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ImportAssignmentsResponse xmlns="http://SelectorPro.SAESystems.com/Import"><ImportAssignmentsResult><Results><ValidCount>4</ValidCount><AssignmentCount>4</AssignmentCount><FailedAssignments/></Results></ImportAssignmentsResult></ImportAssignmentsResponse></s:Body></s:Envelope>
Any help you can give me would be greatly appreciated.
Kevin Wengert - Kinetix Software Solutions
