Question on ssl_error(406)
ronny45
Post by ronny45 »
Hi Scott and team,
I hope someone can help me with this - I am using HTTAPI to get to an internal API endpoint which works from from our Development machine but keeps throwing SSL_Error(406) on Production. Here is the log generated from HTTPAPI:
HTTPAPI Ver 1.49 released 2024-04-16
OS/400 Ver V7R4M0
DNS resolver retry  : 2
DNS default domain: XXXXX.com
DNS server found: 10.221.224.200
DNS server found: 10.222.224.200
DNS server found: 10.223.255.1
SNI hostname set to: internalapi-qa.XXXXX.io
(GSKit) I/O: A connection with a remote socket was reset by that socket.
ssl_error(406): (GSKit) I/O: A connection with a remote socket was reset by that socket.
SetError() #30: SSL Handshake: (GSKit) I/O: A connection with a remote socket was reset by that
OS/400 Ver V7R4M0
http_setauth(): entered
I am thinking it has to do something with the certificates but not exactly sure. I tried using open_ssl command to get the log as well:
openssl s_client -servername hostname -connect internalapi-qa.XXXXX.io:443
CONNECTED(00000004)
write:errno=73
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 314 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
However - this same SSL command returns full Certificate chain in Dev Machine.
Re: Question on ssl_error(406)
For some reason, an error is occurring during SSL negotiation. It appears to be happening with both HTTPAPI and openssl, which tells me that the problem is on the server, not in HTTPAPI.
IT doesn't say what the error is... only that the connection is reset. So for some reason, it is disconnecting. It doesn't say why.
If this server isn't working for anyone, I'd suggest resetting the SSL setup and starting it over.
ronny45
Post by ronny45 »
Thank you so much for your response. Everything works fine from our Development Machine and we get a successful response back. The issue is only with production machine. I am working with the network team to troubleshoot the issue.
