FTPAPI using HTTP Proxy
Discussions related to FTPAPI (An FTP client package for RPG programming.) http://www.scottklement.com/ftpapi/
basim
Re: FTPAPI using HTTP Proxy
Post by basim »
I try to give you some example.
Proxy ip is 185.99.999.98
Final destination ip is 77.73.99.999 port 21
Using EPSV
ftptcp_getPeerAddr(peCtrlSock) return wwhost variable equal to 185.99.999.98 (proxy) port retrieve by message is 32148
pasvcmd return this connection return tcp_conn(wwHost: wwPort: wkTimeout) ----> here wwhost is the proxy
Under tcp_conn we have
if ftptcp_connect( wwSocket
: %trim(peHost) pehost is and proxhost here are the same so the connection failed
: pePort
: wkProxHost
: wkProxPort
: wkProxUser
: wkProxPass)
Using PASV
WWHOST and WWPORT are retrieved from the connection message in this case we have
WWHOST equal to 77.73.99.999 and WWPORT equal to 39486
Hope this can help
Basilio
